MF231 won't start
/ MF231 won't start #1
Butch4
MF231
Help,
Yesterday my MF 231 was running great, like always, and suddenly it appeared to run out of fuel. I confirmed the tank had diesel fuel. It is clean, no water in the fuel filter, and fuel is flowing. The motor will turn over but won't start. What is the next step?
Thanks,
Butch
/ MF231 won't start #2
Where have you checked for fuel flow?Do you have a mechanical shut off or an electrical solenoid shut off?
If you have continuous flow from the tank bottom through to the injector pump inlet, bleed the pump and the injectors.make sure the battery is fully charged and then make sure all the connections, bleed screws, etc are tight first( don't reef them down, just make sure they aren't loose). You might be suckinng air in somewhere. Make sure the tank vent (usually in the fuel cap) is unplugged. If you have good fuel flow to the fuel pump inlet and you can't get fuel at the injectors, I'd suspect the pump.
2026 Electric Tricycle (A64194)
2026 Electric...
(2) New 27X8.5-15 turf tires in John Deere 6-lug compact tractor rims, Coal Valley, IL (A65640)
(2) New 27X8.5-15...
ATS Mini Excavator (A66285)
ATS Mini Excavator...
Woods PRD7200 6' Finishing Mower (A66408)
Woods PRD7200 6'...
MULTIQUIP  Whisperwatt 25 Pull Behind Generator (A62613)
MULTIQUIP...
2016 Ford F-250 Crew Cab Pickup Truck (A64556)
2016 Ford F-250...
