MF230 REAR CRANK OIL LEAK
   / MF230 REAR CRANK OIL LEAK #1
wilber
texas
MF230
We replaced the rear seal and is still leaking,pulled it back apart took the flywheel off and the seal was dry but in looks like the flang that the flywheel bolts onto is pressed onto the crankshaft and apears to be leaking there,is that possible and can that be fixed without pulling the crank?I was wandering if I cut a piece of shim stock to cover the whole flange,put a little sealer on it and bolt the flywheel back on if that would work?
   / MF230 REAR CRANK OIL LEAK #2
Did the old seal score/groove the crank? If so you need to sleeve the crank. If the seal is before the flange, I don't see how the seal can't be leaking.
   / MF230 REAR CRANK OIL LEAK #3
The flange is not pressed on but is part of the crankshaft. It was all turned from the same billet.
Are you sure it is engine oil and not hyd oil leaking out of the input shaft?
   / MF230 REAR CRANK OIL LEAK #4
When the perkins AD152 engine appears to be leaking oil around the rear main it is almost always the oil pan gasket. There is a cork gasket that seals the back of the oil pan. Over time it will harden and leak just like a rear main seal would.
   / MF230 REAR CRANK OIL LEAK #5
my tractor leak after replacing seal of rope type
2013 CATERPILLAR CT660L SBA 6X4 ROAD TRACTOR (A51247)
2013 CATERPILLAR...
Takeuchi Skid Steer (A49461)
Takeuchi Skid...
JOHN DEERE R4023 LOT NUMBER 242 (A53084)
JOHN DEERE R4023...
UNUSED WOLVERINE LHR-51-23W 1R RIPPER (A51248)
UNUSED WOLVERINE...
2024 JOHN DEERE 6155M LOT NUMBER 9 (A53084)
2024 JOHN DEERE...
Adams 5 Ton HC Spreader (A53472)
Adams 5 Ton HC...
