We replaced the rear seal and is still leaking,pulled it back apart took the flywheel off and the seal was dry but in looks like the flang that the flywheel bolts onto is pressed onto the crankshaft and apears to be leaking there,is that possible and can that be fixed without pulling the crank?I was wandering if I cut a piece of shim stock to cover the whole flange,put a little sealer on it and bolt the flywheel back on if that would work?
