MF1540 4x4 front axle oil change
   / MF1540 4x4 front axle oil change
I see it in the pic,on the right.
Better pics.
Are you saying this plastic plug is the fill-level?
   / MF1540 4x4 front axle oil change #15
If I were you I would just look in the large fill hole and fill it until the shaft is almost submerged. That’s what I did for the first 2 years until I got the service manual.
Yep, same recommendation I got earlier.
Thanks for the help.
   / MF1540 4x4 front axle oil change #18
If you get a little too much in it it'll just come out the top a bit. No harm. The fill cap on mine is made to let out overfill.
   / MF1540 4x4 front axle oil change #19
I'm in a similar boat, I have a 2006, the manual has that fill bolt, but jamming my head in there around the loader, it's definitely not there.
I just went with the "fill halfway up the axle shaft" or maybe just a little over that. Certainly not the 7.9 qts it called for…
2009 MINI Cooper Coupe (A50324)
2009 MINI Cooper...
2018 FORD F-550XL SERVICE TRUCK (A51406)
2018 FORD F-550XL...
2013 Ram 4500 Versalift Bucket Truck (A50323)
2013 Ram 4500...
Ford 8N Tractor w/3pt. Buck Saw (AS IS) (A50774)
Ford 8N Tractor...
2007 JOHN DEERE 624J WHEEL LOADER (A51406)
2007 JOHN DEERE...
2018 Bobcat T590 Two Speed Compact Track Loader Skid Steer (A50322)
2018 Bobcat T590...
