MF1540 4x4 front axle oil change
   / MF1540 4x4 front axle oil change
I see it in the pic,on the right.
Better pics.
Are you saying this plastic plug is the fill-level?
   / MF1540 4x4 front axle oil change #15
If I were you I would just look in the large fill hole and fill it until the shaft is almost submerged. That’s what I did for the first 2 years until I got the service manual.
Yep, same recommendation I got earlier.
Thanks for the help.
   / MF1540 4x4 front axle oil change #18
If you get a little too much in it it'll just come out the top a bit. No harm. The fill cap on mine is made to let out overfill.
   / MF1540 4x4 front axle oil change #19
I'm in a similar boat, I have a 2006, the manual has that fill bolt, but jamming my head in there around the loader, it's definitely not there.
I just went with the "fill halfway up the axle shaft" or maybe just a little over that. Certainly not the 7.9 qts it called for…
1996 CATERPILLAR 416B BACKHOE (A51242)
1996 CATERPILLAR...
UNUSED FUTURE GALVANIZED STEEL SITE FENCE (A51244)
UNUSED FUTURE...
DOOSAN DL250 LOADER (A51242)
DOOSAN DL250...
LEE G550 MOTOR GRADER (A51242)
LEE G550 MOTOR...
UNUSED AGT SAII100 QUICK ATTACH PALLET FORKS (A51244)
UNUSED AGT SAII100...
Sunflower 1435-30 Cushion Flex Disc (A52349)
Sunflower 1435-30...
