mf135 power steering
/ mf135 power steering #1
baw1955
1967 mf135
have what i beleive to be 1967 mf135. i just got the tractor the power steering works fine with the wheels off the ground only. took the battery out
and the steering box cover was just laying on it.there was no bolts in it gaskets or shims looks like a little oil in bottom of it. the help I need is ,what oil ,how much ,and is this my problem. thanks brad
/ mf135 power steering #2
I don't know about the oil, However sounds like someone else has been in there before you. When working correctly, the 135 only had power assist and that never was much pumpkin IMHO. Ken Sweet
/ mf135 power steering #3
Diesel or gasser? Standard model or Deluxe model?
The PS unit takes Type A automatic transmission fluid or non-foaming hydraulic fluid, 1 quart.
I have a 1964 MF135 diesel Deluxe with MultiPower.
As for your problem, yeah, it looks like you need to put the steering unit back together, lube it and then test it. Could be a problem with the PS pump also.
its a deluxe I think,it is gas.where could I find bolts for it? thanks
/ mf135 power steering #5
They will be SAE standard. Should be able to pick them up at any dealer or hardware. Probably Grade 5 or 8. Ken Sweet
/ mf135 power steering #6
It's a Deluxe if it has the full complement of gauges (oil pressure, water temp, amps, fuel, tach/hour meter). Otherwise it's the Special (Standard) that has only the water temp and oil pressure gauges.
2022 CATERPILLAR 303.5CR EXCAVATOR (A65053)
2022 CATERPILLAR...
Club Car Carryall 6 Medical Utility Cart (A64553)
Club Car Carryall...
2009 FORD F-750 XL SUPER DUTY DUMP TRUCK (A63276)
2009 FORD F-750 XL...
2019 CATERPILLAR 239D SKID STEER (A65053)
2019 CATERPILLAR...
2015 Dodge Charger Sedan (A61574)
2015 Dodge Charger...
POULAN 44" VINTAGE 2 MAN CHAINSAW (A64276)
POULAN 44" VINTAGE...
