MF135 power steering
/ MF135 power steering #1
Kenfyoozed
Mobile, Al
1974 MF135
I am trying to check if my power steering is working. I am assuming it isn't. It's a 1974 135. I read in my manuals that there should be a power steering fluid resevore. I can not find anything of this nature on my tractor. I have the "cesna" pump on the front left if you are looking at the tractor. Front right if your sitting on it. There are 2 lines that run from it, to the steering column. Im sure grandpa took it off if it stopped working. So what parts am I missing. If I would get the parts manual as suggestd I wouldnt have to ask these questions.:rolleyes:
/ MF135 power steering #2
I think that pump and resevoir are one -- should be a plug on top to fill -- not positive -mine is a gasser, yours must be diesel or 3 cyl gas. As I remember it if the Cessna pump is leaking you can try and fix it but most say replace it. Parts manual has an exploded view. If tyou decide to take it apart, scribe the housing and plate. Otherwise you might do a little bit of swearing when you go to put it back together:mad:
Thanks, after restuding the diagram, I now see that. Thanks.
Mobark Beever M12RX Wood Chipper (A65579)
Mobark Beever...
2009 Infiniti FX35 AWD SUV (A64557)
2009 Infiniti FX35...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
2010 Ford F-350 Crew Cab Diesel (A62679)
2010 Ford F-350...
Dual Tailwheel Rhino 284 7ft Cutter 2.5in cut capacity (A63689)
Dual Tailwheel...
