MF135 Lift is weak?
/ MF135 Lift is weak? #1
jjlanotte
Bronze Member
Sunbury, Ohio
1969 MF135 Perkins Gas
So i just bought a new tiller, my first implement for my 135 perkins gas, and it barely lifts it off the ground. Myabe an inch or so but feels that it mostly just drags it. Is there something wrong with my lift? The tiller weights 850lbs but i feel like it should be able to lift it up further than that. Please help.
/ MF135 Lift is weak? #2
Is your draft control lever all the way back? That's got to be some heavy duty tiller but you should be able to pick it up. Front end will be light. You might want to ask on the vintage MF forum on here as well.
Yeah i tried everything with the draft control, the rated lift is like 2800lbs. So something isnt right
/ MF135 Lift is weak? #4
What hole is the top link in, it makes a dif. as far as height and how much you can pick up?
its in the lower one, and i think its the only one
2000 KENWORTH T800 CRANE TRUCK (A67714)
2000 KENWORTH T800...
CAT 330BL Bucket (A68134)
CAT 330BL Bucket...
2015 Global Environmental Street Sweeper (A64553)
2015 Global...
2013 BOMAG BW211D SMOOTH DRUM ROLLER (A67714)
2013 BOMAG BW211D...
1991 BRENNER TANK TRAILER (A67714)
1991 BRENNER TANK...
Boat Motor. (A66738)
