MF135 iPTO/ clutch removal
   / MF135 iPTO/ clutch removal #1
Browndog122
MF135
I have a MF135 that I'm into a hydraulic pump/ PTO clutch repair on. I'm having trouble figuring out how to remove the hydraulic pump/ PTO clutch and it looks like they have to come out together? Any know-how appreciated.
   / MF135 iPTO/ clutch removal #2
When I do it I split the tractor between the transmission and rear housing. I don't think it comes out the top.
Thanks Harry
As this mf135 is new to me and I'm kinda out in the middle of nowhere, I really appreciate any help on next steps with this one. Since I've had the tractor, the ipto hasn't worked. I just picked up the service manual and I'm trying to work my way through getting things working again.
I have the ipto clutch, Ferguson pump and the hydraulic pump (9gpm) on the bench. Here's what I've found so far:
Ipto clutch -
Brake disc - broken in 4 pieces
Plate (in brake assy) - unevenly worn
Brake piston - 1 edge is mushroomed over and looks to be bent
Clutch housing - heavily scored, where brake disc sits
Wave spring - missing
Hydraulic pump -
Filter - heavily plugged with fouled oil and metal filings
Primary oil circuit line - blown o-ring
Ferguson pump -
Filter assembly - hole torn in Filter
Control valve lever mounting plate (?) - bent towards front of tractor
Should I be looking to replace the entire ipto clutch or just rebuild? Replace scored clutch housing?
Is there a way to bench test any of these components before reinstalling?
Thanks
Komatsu WA250-5L Wheel Loader (A52384)
Komatsu WA250-5L...
2010 MACK PINNACLE (A52472)
2010 MACK PINNACLE...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2011 New Holland Boomer 90 MFWD Utility Tractor (A52748)
2011 New Holland...
2011 Chevrolet Impala Sedan (A51694)
2011 Chevrolet...
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
