MF135 - Can Anyone Identify Please
   / MF135 - Can Anyone Identify Please #1
1968 MF135
Spalding, Lincolnshire
MF135 1968
Hi,
Have the 1968 MF135 stripped for some other work and am slightly puzzled with my Dashboard layout - Maybe the tractor started life as an Industrial version? (traces of yellow paint under the red)
Firstly I seem to have an extra gauge on the dash (the LH big one in the photo below) this is connected via a drive cable to the transmission, but I cant see any photos of a dash layout like this anywhere:
Secondly, can anyone identify what this is with two wires going into it? this is under the battery carrier on top of the transmission:
Thank you for any info :)
   / MF135 - Can Anyone Identify Please #2
I do believe it's the safety switch that prevents starting when the hi lo is not in neutral, the gauge is probably a speedometer.
   / MF135 - Can Anyone Identify Please #3
Is there no symbol on the instrument?
   / MF135 - Can Anyone Identify Please #4
You probably have a MF2135, the industrial twin of the 135.
   / MF135 - Can Anyone Identify Please #6
Hello, can anyone identify and tell what exactly this bolt is called or where to buy one . It is on the fuel filter of a massey 135
   / MF135 - Can Anyone Identify Please #7
It's not really a bolt, but a bolt could be used. It's a plug, Massey number could be 731364M1 with a 731364M1 washer. .It is a 1/2" S.A.E. thread, so you could use a bolt if you can find one fully threaded and cut it short enough to fit. Any proper size copper or aluminum sealing washer should work.
   / MF135 - Can Anyone Identify Please #8
Yup, reply #2 is right, it's the neutral safety switch.
Reply #4 is correct industrial version, it's the only one with an external dash light.
2021 JOHN DEERE 648LB GRAPPLE SKIDDER (A52705)
2021 JOHN DEERE...
(INOP) 2016 AUTOCAR EXPEDITOR GARBAGE TRUCK (A51406)
(INOP) 2016...
UNUSED WOLVERINE PFA-11-3300G HYD PALLET FORKS (A54757)
UNUSED WOLVERINE...
2006 CHEVROLET EXPRESS SERVICE VAN (A54313)
2006 CHEVROLET...
2023 Chevrolet Tahoe (A55853)
2023 Chevrolet...
SHOP BUILT FLARE STACK (A53843)
SHOP BUILT FLARE...
