MF135 - Can Anyone Identify Please
   / MF135 - Can Anyone Identify Please #1
1968 MF135
Spalding, Lincolnshire
MF135 1968
Hi,
Have the 1968 MF135 stripped for some other work and am slightly puzzled with my Dashboard layout - Maybe the tractor started life as an Industrial version? (traces of yellow paint under the red)
Firstly I seem to have an extra gauge on the dash (the LH big one in the photo below) this is connected via a drive cable to the transmission, but I cant see any photos of a dash layout like this anywhere:
Secondly, can anyone identify what this is with two wires going into it? this is under the battery carrier on top of the transmission:
Thank you for any info :)
   / MF135 - Can Anyone Identify Please #2
I do believe it's the safety switch that prevents starting when the hi lo is not in neutral, the gauge is probably a speedometer.
   / MF135 - Can Anyone Identify Please #3
Is there no symbol on the instrument?
   / MF135 - Can Anyone Identify Please #4
You probably have a MF2135, the industrial twin of the 135.
   / MF135 - Can Anyone Identify Please #6
Hello, can anyone identify and tell what exactly this bolt is called or where to buy one . It is on the fuel filter of a massey 135
   / MF135 - Can Anyone Identify Please #7
It's not really a bolt, but a bolt could be used. It's a plug, Massey number could be 731364M1 with a 731364M1 washer. .It is a 1/2" S.A.E. thread, so you could use a bolt if you can find one fully threaded and cut it short enough to fit. Any proper size copper or aluminum sealing washer should work.
   / MF135 - Can Anyone Identify Please #8
Yup, reply #2 is right, it's the neutral safety switch.
Reply #4 is correct industrial version, it's the only one with an external dash light.
6 Yard Commercial Dumpster (A51691)
6 Yard Commercial...
UNUSED LANDHONOR MGB-72-44W 44" MINI GRAPPLE BKT (A54757)
UNUSED LANDHONOR...
2008 Isuzu NPR-HD Landscape Dump Truck (A55788)
2008 Isuzu NPR-HD...
UNUSED LANDHERO LDH-T460 STAND ON SKID STEER (A54756)
UNUSED LANDHERO...
2006 Magnum 125 125kW T/A Towable Diesel Generator (A55787)
2006 Magnum 125...
Eager Beaver 20XPT (A47477)
Eager Beaver 20XPT...
