MF1140 Engine cutting out
/ MF1140 Engine cutting out #1
GooseThunderfoot
Western NC
MF 1140
Hi folks, this is my first post here. I'm using an old and severely neglected MF 1140 to mow an overgrown field with a bushhog attachment, but the motor keeps cutting out. At first I thought it was the Mower/PTO placing too much of a load on the engine (5 acres of 4-foot weeds), but then the tractor cut out again when I was driving it back to the shed. When it cuts out, it sounds a lot like when you turn it off properly by using the Fuel Shut-Off Knob (very slow and gradual). On the 5th time the engine started to die, I depressed the clutch, put the throttle on minimum and pulled the fuel shut-off knob. Just before the motor came to a stop, I pushed the knob back into the running position and the engine sputtered back to life. Any ideas what's wrong? Thanks in advance!
-Goose
I'm not sure if this community has a policy against bumping threads, but any response or redirection to a more appropriate forum would be much appreciated!
/ MF1140 Engine cutting out #4
G'day change fuel filter/s remove fuel tap from tank and check filter into tank
also check screen in prime pump
Jon
2023 John Deere 6120M Tractor (A63109)
2023 John Deere...
2014 FVCG TRAILER (A61567)
2014 FVCG TRAILER...
2005 INGERSOLL-RAND SD-116F TF  ROLLER (A59910)
2005...
CAT Flat Bottom High-Capacity Material Bucket (A64047)
CAT Flat Bottom...
2007 Ford Crown Victoria Sedan (A61574)
2007 Ford Crown...
2013 Kubota BX2370 54in 4x4 Compact Utility Tractor Mower with 48in Rotary Brush Cutter (A61572)
2013 Kubota BX2370...
