MF GC2410 Coolant Leak
   / MF GC2410 Coolant Leak #1
dlmorin1
Norfolk MA
MF GC2410 Tractor/Loader/Backhoe
I have an MF GC2410 that has a coolant leak and I don't know how to fix the leak. As you can see by the picture the leak is just above the green coolant. It is coming from what appears to be an aluminum covered bolt that is just above the throttle cable on the left side of the motor. The cover over the bolt moves but I don't know how to get the cover off to see what is going on and I don't want to break anything in the process of removing the cover.
Does anyone have a shop manual that can give me some direction on identitfing the leak?
Problem resolved found the leak...
   / MF GC2410 Coolant Leak #3
And what was leaking?
Lower Radiator Hose was rubbing on the throttle linkage, replaced hose adjusted hose away from throttle linkage, problem solved...
2015 JOHN DEERE 624K WHEEL LOADER (A51406)
2015 JOHN DEERE...
MODERN AG PREDATOR 15 15' BATWING MOWER (A51406)
MODERN AG PREDATOR...
2007 Dodge 3500, 6.7 Cummins, Automatic (A52384)
2007 Dodge 3500...
RYOBI 18V ELECTRIC 13" PUSH LAWN MOWER (A51248)
RYOBI 18V ELECTRIC...
2025 MAX BUILT 82" X 20' TRAILER (A51247)
2025 MAX BUILT 82"...
UNUSED FUTURE SF60 HYD MAST W/ 60" FORKS (A51248)
UNUSED FUTURE SF60...
