MF gc 2310 2375 backhoe doesn't work.
/ MF gc 2310 2375 backhoe doesn't work. #1
vwdoc
New Hampshire
2004 GC2310 TLB
None of the controls work on the back hoe. It did it once last year and has been fine. I swapped the spool valves and made shure the fluid is flowing good, I swapped the input lines and blew the fluid out both ways... seems to be getting great flow. change hydraulic fluid & filter every 2 years using MF dealer parts. Tractor goes back & forth fine and front bucket works great.. I figured it would be one of the valves in the block... Any help would be great thanks..
And machine is a 2004 and has 315 hours on it.
/ MF gc 2310 2375 backhoe doesn't work. #2
You might want to post in the Massey Ferguson Owner/Operating Forum with a more detailed description. It is confusing to read.
Ok I will post it there. I figured hydraulics and the hydraulic block on these compacts were very close to being the same. but I don't understand what's confusing Please explain..
2023 ANDERSON IFX720 CONTINUOUS BALE WRAPPER (A64277)
2023 ANDERSON...
2023 UTILITY VS2RA 53X102 REFRIGERATED TRAILER (A59914)
2023 UTILITY VS2RA...
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A61567)
2016 Ford F-150...
John Deere Pallet Forks (A66285)
John Deere Pallet...
2022 EZ-GO ELITE...
2001 INT 4900 DT 530 (A62679)
2001 INT 4900 DT...
