MF clutch problem
/ MF clutch problem #1
dirtfarm
tn
mf 175
I have a MF 175, I've only had the tractor a short time. multi-power was removed before I got it. 3hi 3 low. when I press the clutch trans gears keep turning I adjusted it as far as I can. once it's in gear there is no slipping.
thanks for any help or suggestions
/ MF clutch problem #2
Clutch disc "froze" to flywheel.....Can be result of rust, oil on clutch facing, or a number of possibilities.
/ MF clutch problem #3
With it in gear can you stop the tractor by pushing in the clutch? If not I agree it is probably the clutch frozen to flywheel or pressure plate.
If you can stop the tractor in gear by pushing the clutch in, it may be the clutch lining has came off and is stacked up making it too thick, or the pressure plate springs have twisted sideways and will not allow it to release...
Did this suddenly happen or gradually get worse? KennyV
/ MF clutch problem #4
yep.. I agree with the others.. sounds like classic stuck clutch.. FWJ hit the usualy culprets.
block the clutch overnight and see if that helps.. you can also try to bump it over in high gear. with clutch blocked and brakes locked a few times to pop it loose if setting blocked don't help.
soundguy
/ MF clutch problem
Thanks for your response's. I've adj. the clutch as far as I can and can get it in gear with little grinding, it won't move till I let out on the clutch. the wheels shimmy abit (more than they should). I pulled the plate off under the bellhouse and found a smooth rod about 3 inches long the diameter of a pencil. one end has a hole drilled in to it and is broke right at the hole. looks like i'm going to be spliting the tractor. any info on the small rod would be helpful
thanks
/ MF clutch problem #6
doesn't look like a greas tube does it?
soundguy
/ MF clutch problem #7
thanks
Well....That explains why the clutch doesn't work.
Time to split the tractor...... :(
That's MOST of one of the three clutch release lever pivot pins. Parts manual refers to it as 5/16" X 2-11/16" long. The hole WAS where the retainer went through.
Clutch assembly will need to be disassembled to replace. Time for a new clutch while you're at it.
/ MF clutch problem #8
... looks like i'm going to be spliting the tractor...
You're probably right. Splitting a tractor is like getting bucked off a horse... It's not quite so scary after you've done it a time or two.
Be sure to disconnect everything between the front and back before you try to split it. There's nothing like trying to hold the two halves of a tractor together while you undo that last wire that you forgot.
Keep us posted on your progress. As others have said, replace what you can while you're in there.
/ MF clutch problem
Thank's for all the help I'll keep you all informed.
/ MF clutch problem #10
That may be but it still hurts.:)
/ MF clutch problem #11
Dad always said that as soon as a horse starts bucking you have to decide right then to either ride it out or find a soft spot to land. Now I'm trying to figure out how to relate that to splitting a tractor.
I've done it twice now on two different tractors. It takes a lot of time, but at no point is it really difficult.
UNUSED JCT 4 PRONG BALE SPEAR (A62131)
UNUSED JCT 4 PRONG...
UNUSED (2) 3" HYD CYLINDERS (A62130)
UNUSED (2) 3" HYD...
2024 ANKONA 54" HANG-ON WHEEL LOADER FORKS (A62129)
2024 ANKONA 54"...
UNUSED ATS PA400 ELECTRIC HOIST (A62131)
UNUSED ATS PA400...
2014 Ford Econoline Van, VIN # 1FDEE3FL6EDB17703 (A61165)
2014 Ford...
2017 Load Trail 22ft. 7 Ton T/A Equipment Tilt Trailer (A61569)
2017 Load Trail...
