Mf 675 draft controll spring adjustment.
/ Mf 675 draft controll spring adjustment. #1
reyerd
silsand
ih574, mf675
Mf 675 draft controll spring adjustment, some years ago when using winch behind tractor, the clevis was ripped of the plunger and destroyed all threads. So i had to change out these parts. After this 3 point hitch has been weak, not willing to lift what it before lifted. I read yesterday a forum thread someone with same problem had created, they tried removing top link. And using a strap instead, tied somplace else. It went up, no problems, but attaching top link, it wont move. This i tried, same with my tractor, but If i go outside helping the attachment up it goes up.
So trying to adjust this spring. Have removed pin and adjusted clevis so i can turn spring by hand. No i should adjust nut to remove end play. What is end play? Im from norway and maybe im not understanding it correct, when tightening all the way in. Still i can move the clevis around a bit, up down and to the sides. Is this end play? Or when tightening, is it to when i cant move it in and out anymore. At one point it hitting this spring loaded tap inside housing, then i can push it in and it comes out again, or should i tight this to the point that the tap wont move anymore?
/ Mf 675 draft controll spring adjustment. #2
Endplay is if you can move that eye in and out.To loose AND to tight wil give you endplay.Just turn it til all the endplay is gone. If you go more the endplay will appeare again.
No i tried adjusting to right when i cant move it in and out, and now it wont lift the attachment at all. Now i use big crowbar to help it up, and i struggle. Before i started, i could help only with hands. Removing top link make it lift.
2015 CHEVROLET 2500 HD CREW CAB FLATBED TRUCK (A62130)
2015 CHEVROLET...
2022 EZ-GO ELITE...
Wacker Neuson EZ26 (A60462)
Wacker Neuson EZ26...
ROADTEC RX700 MILLING MACHINE (A62129)
ROADTEC RX700...
300 Gallon Portable Fuel Tank (A64127)
300 Gallon...
2001 KENWORTH W900 72" STUDIO SLEEPER (A62613)
2001 KENWORTH W900...
