MF 65 Wheels
   / MF 65 Wheels #1
muck0228
houston, tx
MF 65
I have a MF 65. The rear wheels have been full of water and are rusting through from the inside. The wheels are power adjustable 13-28. Where can I find replacement rims or are there alternate rims that will fit?
thanks
   / MF 65 Wheels #2
Your tire should need 12 inch wide rim. Ford, AC, and IH also used 4 rail spin out wheels if that is what you have, but check rail stop holes, some are straight, some are angle drilled. If you don't adjust anymore and tires are bad 8 bolt combine wheels will fit also, thats how my dad fixed his 65, just can't adjust them anymore.
   / MF 65 Wheels #3
thanks
Those rims are not hard to find. Most dealers sell for around 100-125 bucks each plus shipping. It cost me recently 100 to have a new tube put in a unloaded wheel. When budgeting the rims. Evaluate your tires if they need replaced. I've seen many moderately used tractors with badly rotted tires. When you finally do replace them, put an environmentally friendly liquid in the tires. If you have the spin out type rims, they are pricy. Usually around 300 each. Good luck. -Robert
2015 Cadillac ATS Sedan (A51694)
2015 Cadillac ATS...
2015 John Deere 5085M (A50120)
2015 John Deere...
2017 Hyundai Tucson SUV (A50324)
2017 Hyundai...
2016 INTERNATIONAL PROSTAR TANDEM AXLE SLEEPER TRUCK (A52141)
2016 INTERNATIONAL...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
