MF 65 Wheels
   / MF 65 Wheels #1
muck0228
houston, tx
MF 65
I have a MF 65. The rear wheels have been full of water and are rusting through from the inside. The wheels are power adjustable 13-28. Where can I find replacement rims or are there alternate rims that will fit?
thanks
   / MF 65 Wheels #2
Your tire should need 12 inch wide rim. Ford, AC, and IH also used 4 rail spin out wheels if that is what you have, but check rail stop holes, some are straight, some are angle drilled. If you don't adjust anymore and tires are bad 8 bolt combine wheels will fit also, thats how my dad fixed his 65, just can't adjust them anymore.
   / MF 65 Wheels #3
thanks
Those rims are not hard to find. Most dealers sell for around 100-125 bucks each plus shipping. It cost me recently 100 to have a new tube put in a unloaded wheel. When budgeting the rims. Evaluate your tires if they need replaced. I've seen many moderately used tractors with badly rotted tires. When you finally do replace them, put an environmentally friendly liquid in the tires. If you have the spin out type rims, they are pricy. Usually around 300 each. Good luck. -Robert
2011 JCB 541-70 TELESCOPIC FORKLIFT (A51242)
2011 JCB 541-70...
2017 MACK CHU613 TANDEM AXLE SLEEPER (A51222)
2017 MACK CHU613...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
New 4x6 Chicken Coop (A50774)
New 4x6 Chicken...
2015 FORD F750 26FT BOX TRUCK (A51219)
2015 FORD F750...
2014 Chevrolet Spark Hatchback (A50324)
2014 Chevrolet...
