MF 65 Wheels
   / MF 65 Wheels #1
muck0228
houston, tx
MF 65
I have a MF 65. The rear wheels have been full of water and are rusting through from the inside. The wheels are power adjustable 13-28. Where can I find replacement rims or are there alternate rims that will fit?
thanks
   / MF 65 Wheels #2
Your tire should need 12 inch wide rim. Ford, AC, and IH also used 4 rail spin out wheels if that is what you have, but check rail stop holes, some are straight, some are angle drilled. If you don't adjust anymore and tires are bad 8 bolt combine wheels will fit also, thats how my dad fixed his 65, just can't adjust them anymore.
   / MF 65 Wheels #3
thanks
Those rims are not hard to find. Most dealers sell for around 100-125 bucks each plus shipping. It cost me recently 100 to have a new tube put in a unloaded wheel. When budgeting the rims. Evaluate your tires if they need replaced. I've seen many moderately used tractors with badly rotted tires. When you finally do replace them, put an environmentally friendly liquid in the tires. If you have the spin out type rims, they are pricy. Usually around 300 each. Good luck. -Robert
2003 FREIGHTLINER FL80 DUMP TRUCK (A51406)
2003 FREIGHTLINER...
Tree Boom (A50322)
Tree Boom (A50322)
Land Honor 84" 3 pt Disk (A50514)
Land Honor 84" 3...
2021 ALLMAND BROS, INC. NIGHT LITE LIGHT TOWER (A50854)
2021 ALLMAND BROS...
2019 MMDI 14ft T/A Utility Trailer w/ Fuel Tank (A48082)
2019 MMDI 14ft T/A...
FUEL TANK (A50854)
FUEL TANK (A50854)
