MF 6180 pto/transmission/sensor problems
/ MF 6180 pto/transmission/sensor problems #1
Can Fixit
1997 6180 sheared off pto sensor tonite.Always leaked oil from pto flange,change large o-ring watched leak still appear.Put a magnet into bottom back of pto case and pulled up a 2.5 inch diameter steel casting plug that was hidden behind drawbar support frame. Oil leak was probably from that plug all this time,until it fell out into the transmission,or maybe sat on the bottom for a long time.Was going up a steep hill with pto on when it sheared the sensor.The plug got caught up in the gears of the pto inside then fell back to the bottom.Any one else has this problem?Got the plug out but some of the sensor,plastic part,not magnet,is in the bottom in the oil Thx
Location Info Please
2004 Cadillac Eagle Ultimate Hearse, Eagle Coachbuilders, Hearse Collector Special (A63689)
2004 Cadillac...
(2) 10ft Nesting Boxes (A65579)
(2) 10ft Nesting...
3/8" Quick Attach Blank Plate (A66408)
3/8" Quick Attach...
2012 Husqvarna YTH21K46 46in. Riding Lawn Mowers (A64557)
2012 Husqvarna...
2019 FORD F-550 SUPER DUTY (A65643)
2019 FORD F-550...
