MF 500 Series
   / MF 500 Series #11
mfendtguy said:
The 500 Series are just updated versions of the 400 series and still use 3 and 4 cylinder Perkins engines. The Challenger 300 Series is the same as the MF 3600 Series which you haven't seen yet and won't see pictures of until the dealer new product intro in St. Louis later on this month. The 3600 Series will have 3 cylinder SISU motors and basically be a "bridge" between the low-spec 400 Series and the higher spec-ed (and heavier) 5400 series (which use both Perkins and SISU motors).
There will be 3 models in the 3600 Series I believe 55, 65, 75 hp. Powershuttles will be an option as well as cabs. The 3600 series probably won't show up on dealer lots until later on this fall.
Hey,
Thanks for the info. Sounds like a good option for those who want a little more than a 400 series, but not enough to justify getting a 5400.
Thanks,
Will
   / MF 500 Series #12
EquipmentUser said:
I thought all the 5400 series tractors used perkins. I know for sure all the 4 cylinder models do and I think there's only one 6 cylinder model, the 5465 and I figured it used the same 6 cylinder perkins as the three smallest models of the 6400/7400 series tractors.
You don't know about the 5470 then. It uses the 4.4 liter SISU 4 cylinder and is rated at 105 PTO hp. The 5470 is only available with a cab and the Dyna-4 transmission.
   / MF 500 Series #13
Come to think of it I did see one at the dealer the other day. You know a lot about the massey's, are you a dealer or a rep for Agco? I wonder why they switched over to the Sisu for that model instead of just using the 6 cylinder perkins. Do you know if the dyna 4 is available on all the 5400 series? Is it standard or optional?
   / MF 500 Series #14
In regards to your 1st question-let's just say I stay on top of such things (watch what MF has in Europe and you'll have a good idea, they're usually 6-12 months ahead over there).
I don't know why they are using the SISU other than they are trying to get a good power to weight ratio, plus the 5470 is a cheaper alternative to the 6475.
And yes, the Dyna-4 is optional on all of the 5400's except the 5470 where it is standard.
   / MF 500 Series #15
With AGCOs purchase of Valtra they also picked up SISU engines in the deal. Don't be surprised if that engine doesn’t start showing up in more AGCO products. They will more than likely have to keep using Perkins to a large extent but will also add a number of SISU powered machines.
   / MF 500 Series #16
Hey,
The 5470 is not on the MF ( NA ) website yet.... Are you a dealer or an MF rep??
Thanks,
Will
   / MF 500 Series #17
WilliamBos said:
Hey,
Thanks,
Will
Check out MF's Euro website (UK/Eire) it will show the 5470 there. The MF USA/Canada site is usually a couple months behind.
   / MF 500 Series #18
Hey,
I checked out the Euro english site. Looks like they have some real nice stuff headed our way soon!! That new Dyna 4 on the 5400 sounds amazing. And being able to get a 5400 ( 5470 ) with over 100 pto HP is nice too!!
New/Unused Skid Steer Hammer (A57454)
New/Unused Skid...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58216)
HYDRAULIC THUMB...
7 30 inch reels (A59228)
7 30 inch reels...
2014 International Derrick Digger Truck (A55973)
2014 International...
(APPROX. 26) 4' X 8' X 3/4" OSB SHEETS (A52706)
(APPROX. 26) 4' X...
(4) TOYO M/T OPEN COUNTRY TIRES (A58376)
(4) TOYO M/T OPEN...
