Mf 471 Bleeding your fuel system.
/ Mf 471 Bleeding your fuel system. #1
1farmerJohn
2001 massey ferguson 471
I have a 471. My fuel filter was I little loose and I didn't know it. I started the tractor and it ran for a bit and died. I'm assuming I have air in the lines. This tractor is a little different than my 1958 so I really can't tell for sure how to bleed the air out please help.
/ Mf 471 Bleeding your fuel system. #2
Don't know squat about your tractor but I would break the injector lines at the injectors and crank it over until the fuel flow is solid with no visible air bubbles coming out.
Both my Kubota's have a bleeder screw (small handwheel) on the pumps that evacuate any air in the system. Never had the occasion to use it however.
/ Mf 471 Bleeding your fuel system. #3
Check your owner's manual - either in print or online. Bleeding different brands and models varies that much.
/ Mf 471 Bleeding your fuel system. #4
One thing for certain and that is, if no air is present at the injector connections, being the end of the line for fuel, no air means the entire system is solid fuel.
/ Mf 471 Bleeding your fuel system. #5
Correct.. neither inj pumps that are for that engine, Delphi DP200 (8920) or the VE pumps have a bleeder screw.. so if u can get to the injectors, loosen the nut AT THE INJECTORS just a turn or 2 and crank the engine until fuel squirts out with no air bubbles and tighten..
Good luck and Happy Thanksgiving..
2018 Ram 1500 Reefer Meal Delivery Truck (A61573)
2018 Ram 1500...
UNUSED IRMC HIGH END MASSAGE CHAIR (A64281)
UNUSED IRMC HIGH...
2014 International WorkStar 7300 4x4 Altec AA55E 55ft. Material Handling Bucket Truck (A60460)
2014 International...
2007 John Deere 644J Articulated Wheel Loader (A59228)
2007 John Deere...
2019 KOMATSU D51EX-24 CRAWLER DOZER (A64279)
2019 KOMATSU...
Frontier Hay Spear (A64126)
Frontier Hay Spear...
