sawtooth
Veteran Member
- Joined
- Sep 19, 2007
- Messages
- 1,192
- Location
- Eden NC
- Tractor
- Ford NAA, Ford 2810, Ford 3910-1, Ford 3910-2, Ford 4600SU, Massey 2660 HD, Massey 461, Grasshopper 725D, Grasshopper 900D
Guys,
My 461 has about 450 hours on the clock and it overheats while brush hogging. The radiator looks clear but the fuel cooler has some grass etc in it from the previous owner. Not sure why you cool the fuel anyway but could that be the issue? Other issue is the stuff is caked in there and I'm not able to get behind it to clean it very well. Basically the tractor is ok till i start the cutter. Then in high grass about 5-10 min later it over heats. What should i look for? I think i found the water pump and it was smoking hot. Not sure how to tell what the problem is though. As for the temp i shut the engine down right as it was going into the red zone on the temp gauge. Hopefully there is no permanent damage. Any help would greatly be appreciated.
Thank you
Thank you
