MF 4235 Road Speed sensor location?????
   / MF 4235 Road Speed sensor location????? #1
banjodunn
Ararat Vic Aus
G'day all I have a 4235 here and it is giving me a code 62 on the power shuttle that relates to road speed sensor, the prob I have is the only speed sensor I can find in the parts book relates to a radar speed sensor on the rear axle housing and it is not fitted to this tractor, can anyone tell me where another sensor might be located please.
Jon
   / MF 4235 Road Speed sensor location????? #2
Try as I might, I can't figure out what a radar speed sensor on a tractor would do.
All the radars I have had to do with point at the ground to give you a wheel slip sensor but this one shows it pointing to the rear axle flange so they must use it for road speed but how can one give a fault if it is not fitted??
Jon
   / MF 4235 Road Speed sensor location????? #4
I hope someone can help you. It's far too sophisticated for me.
   / MF 4235 Road Speed sensor location????? #5
I have a 4345 and have gotten that flash. Next time it does flash, twist the clutch speed engagement knob on the left of the column and see if it doesn't stop flashing. These things have quirk electronics.
Cheers I will try that thank you
Jon
2020 INTERNATIONAL MV607 24FT NON CDL BOX TRUCK (A52576)
2020 INTERNATIONAL...
2005 IH 7600 t/a Dump Truck (A52384)
2005 IH 7600 t/a...
2025 JOHN DEERE Z325E LOT NUMBER 87 (A53084)
2025 JOHN DEERE...
3 Point 5 1/2ft Metal Screen Cargo Carry (A51573)
3 Point 5 1/2ft...
2017 John Deere 8345R MFWD Tractor (A53342)
2017 John Deere...
2015 FREIGHTLINER SPRINTER VAN (A52576)
2015 FREIGHTLINER...
