MF 4235 Road Speed sensor location?????
   / MF 4235 Road Speed sensor location????? #1
banjodunn
Ararat Vic Aus
G'day all I have a 4235 here and it is giving me a code 62 on the power shuttle that relates to road speed sensor, the prob I have is the only speed sensor I can find in the parts book relates to a radar speed sensor on the rear axle housing and it is not fitted to this tractor, can anyone tell me where another sensor might be located please.
Jon
   / MF 4235 Road Speed sensor location????? #2
Try as I might, I can't figure out what a radar speed sensor on a tractor would do.
All the radars I have had to do with point at the ground to give you a wheel slip sensor but this one shows it pointing to the rear axle flange so they must use it for road speed but how can one give a fault if it is not fitted??
Jon
   / MF 4235 Road Speed sensor location????? #4
I hope someone can help you. It's far too sophisticated for me.
   / MF 4235 Road Speed sensor location????? #5
I have a 4345 and have gotten that flash. Next time it does flash, twist the clutch speed engagement knob on the left of the column and see if it doesn't stop flashing. These things have quirk electronics.
Cheers I will try that thank you
Jon
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A51694)
2015 Toro Multi...
WESSEX RMX500 LOT NUMBER 44 (A53084)
WESSEX RMX500 LOT...
2025 New/Unused Wolverine Vibratory Roller (A51573)
2025 New/Unused...
2005 Nissan Titan (A50121)
2005 Nissan Titan...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
2025 New/Unused 72in Skid Steer Brush Cutter (A51573)
2025 New/Unused...
