MF 4235 Road Speed sensor location?????
   / MF 4235 Road Speed sensor location????? #1
banjodunn
Veteran Member
Ararat Vic Aus
G'day all I have a 4235 here and it is giving me a code 62 on the power shuttle that relates to road speed sensor, the prob I have is the only speed sensor I can find in the parts book relates to a radar speed sensor on the rear axle housing and it is not fitted to this tractor, can anyone tell me where another sensor might be located please.
Jon
   / MF 4235 Road Speed sensor location????? #2
Try as I might, I can't figure out what a radar speed sensor on a tractor would do.
All the radars I have had to do with point at the ground to give you a wheel slip sensor but this one shows it pointing to the rear axle flange so they must use it for road speed but how can one give a fault if it is not fitted??
Jon
   / MF 4235 Road Speed sensor location????? #4
I hope someone can help you. It's far too sophisticated for me.
   / MF 4235 Road Speed sensor location????? #5
I have a 4345 and have gotten that flash. Next time it does flash, twist the clutch speed engagement knob on the left of the column and see if it doesn't stop flashing. These things have quirk electronics.
Cheers I will try that thank you
Jon
COOPER LIGHTING CAT. NO. MHEP-22/28-175-MT (A53472)
COOPER LIGHTING...
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
2025 New/Unused Min Skid Steer Loader (A51573)
2025 New/Unused...
(1) HD 24ft Free Standing Corral Panel with 7ft Gate (A51573)
(1) HD 24ft Free...
Ground Works Fertilizer Spreader (A51573)
Ground Works...
