3-Point Hitch MF 3635 3 point hitch
/ MF 3635 3 point hitch #1
brandon327
Question #1
What are the 2 knobs under the seat for? I think they go to the 3 point hitch but what do they do?
Question #2
I hooked to our disc for the first time today and they tractor will pick it up plenty high in the front but not it in the back. I set the backbone all the way in and tried it in all the 3 holes and nothing helped. I think the backbone is too long. So i tried the backbone off of our John Deere which is shorter and i could get it short enough to get it up off the ground. But with either backbone no matter how i set it when i started disking the front set of gangs sunk in the ground then the rear of the disk came completely off the ground. So i adjusted the backbone ever way and nothing helped. It seems like the 3 point hitch goes to low. When you go to raise the 3 point hitch it is either up or down there is no in between? I think there are about 6 or 7 hitch postions and it does not make any upward motion till it gets to about 5. I do not have any of these problems out of the John Deere. I eneded up hooking the disk to the JD and using it. I am starting to think i made a mistake buying the MF. But i do like the MF more than the JD.
/ MF 3635 3 point hitch #2
I don't know what the second knob is for but one of them is to set the rate of drop speed for the implement on the three point hitch.
I don't know what you are calling the backbone.
What you need to do is make the third arm, the single arm that mounts from the top of the disc to the tractor, longer. Twist the middle to make it longer or shorter in this case make it longer. That will level the disc out.
The numbers are just there for your future reference. When you get everything set up, then you know you are at the same depth if the lever is at say a 3 this pass if it was at a 3 the last pass.
Do you have a owners manual?
/ MF 3635 3 point hitch #3
1. The 1 knob is to set the rate of drop the other is for draft sensitivity control.
2. If you can only get up or down, no positions in between it is in draft mode not position mode. Me thinks you need to spend a little time with your owners manual, I know reading is less fun than doing, but some times we have to do it.
Frank
/ MF 3635 3 point hitch #4
Yeah, the 3pt is just not set properly. It's not a "brand" problem. Sounds like the top link isn't the right length and the draft isn't set up the right way for your harrows.
I wish i could read the manual but i bought the tractor used and i do not have an owners manual. I am not blaming it on the brand i was just frustrated when i was writing that. I like the tractor better than the deere except for that one issue.
/ MF 3635 3 point hitch #6
You should contact a Massey Dealer and pick up an owners manual, or try to find one online. That tractor has a lot of nice features, you'll be pulling your hair out figuring them out by trial and error.
But have fun playing with it, I'm sure you'll figure some things out. There should be a handle near the 3pt lift handle that controls the draft function.
Frank
/ MF 3635 3 point hitch #7
I'm gonna short hand it a bit cause I'm not a typer
"A" lever being the front or closest to the operators platform - Position Control Lever
"B" being the rearward lever- Draft Control Lever
Mounted Implements:
To adjust working depth, move in the following order:
Lever "A" Forward
Lever "B" Forward
drive forward and adjust Lever "B" progressively to obtain desried depth
Operations:
At the end of the run move lever "A" back to lift the implement
At run start, move lever "A" forward to send implement into operation
To maintain the same depth don't move lever "B"
When adjusting draft control,the sensitivity knob, on the right hand side of the tractor, remains open
Note if the rear of the implement raises too much, raise the top link mounting hole position. Reverse if it doesn't lift enough.
The other knob under the seat adjusts rate of drop.
Thanks for all the info. I have just never had to use the draft function for anything. We have always left them in the down postion and went about our business.
/ MF 3635 3 point hitch #9
I just picked up the operators manual for my MF 175 from the dealer and was surprise that they only ran around $12. Well worth the money in my opinion. Of course they did make up for it on the parts manual $65 (ouch).
I called the dealer today and the operators manual for that tractor is $50. I think i am gonna play with it and see what i can figure out before i drop $50 on a operators manual.
/ MF 3635 3 point hitch #11
The Operators Manual is a good investment for any machine. $50 may seem high but it not only gives you operation information but maintenance, basic troubleshooting and wiring diagrams. That can save you time and money in the future. That's less than an hour of labor in most shops for something you could do yourself.
Is there a possibilty that the draft and postion lever are labeled wrong. I am thinking maybe they are backwards. the one closest to the fender being the postion lever and the other being the draft lever. The one next to the fender has a longer handle on it.
/ MF 3635 3 point hitch #13
Hello, brandon327, The long lever is the draft control (round head) and the short lever closest to the seat is the position control(square head). MF 135,178,240,275,376 are all like this
When not if you get your manual you will curse not getting it earlier. You will quickly tear out $50 of metaphorical hair.
/ MF 3635 3 point hitch #14
If it were me I'd first just try to get it working with position control only. Rarely is draft control a must for a 3 point disc.
Maybe there's some other problem with the hydraulics. Is the tractor able to lift other heavy implements all the way up high? Some tractors have an adjustment knob to limit the lift height to prevent damage to PTO shafts on rotary cutters, etc. Not sure about your MF. Check that when you have the 3 point raised all the way with no load it is going almost all the way up. Then be sure it's going to the same height with the disk on.
Are there any pins where the lift arms attach that you can move to a higher position? Also be sure they are not in a slotted position for floating, you want it in a fixed hole. If it works on the JD, how high is the JD lift arm off the floor when all the way up? Does the MF lift to the same height or higher with a load on it?
/ MF 3635 3 point hitch #15
Add PSIf the front is digging in and the back is up in the air obviously the upper lift arm is set too short. If you had to make it that short to get off the ground in the first place you have some other problem. Like I said in the other post, try running it with the position control only; leave the draft lever all the way down. Usually the lever with the numbers is the draft control, not the position control; try it all the way down on the lowest number.
Question #1
Question #2
PS. The reason the "backbone" is longer on the MF is that a lot of these Italian built tractors do not conform to the ASAE standards for CAT 2 3pt hitch. The horizontal distance from the PTO shaft to the link ends is greater on many of the Italian made tractors. Also the horizontal distance from the top link on the tractor to the link ends. I'll bet when you hook up a PTO implement to the tractor you will have to extend the PTO shaft more than on your JD; you might even need a longer shaft. Anyways I'd use the link that came with the tractor, if possible.
Stil, from the way you describe the lift is working I think you're trying to raise it with the draft lever. Maybe it's mislabelled or maybe you're reading it wrong.
Please let us know what the problem was and how you fixed it. Good luck.
2019 Toro Workman GTX Electric Utility Cart (A59228)
2019 Toro Workman...
CASE IH STEIGER 400 HD TRACTOR (A58375)
CASE IH STEIGER...
2024 Kubota RTVXG850GLAS24-A Sidekick Utility Vehicle - 19 hours
2024 Kubota...
SKID STEER ATTACHMENT MULCHER (A58214)
SKID STEER...
Swict 72in. Skid Steer Bucket (A59228)
Swict 72in. Skid...
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
