MF 36 Hay Rake, is it a good rake?
   / MF 36 Hay Rake, is it a good rake? #1
corey9212
Platinum Member
Red Deer County, AB
2015 John Deere 3046R
Hello, I got a chance to get a MF 36 Hay Rake tomorrow for $400. Being new at all this I was wandering how good of a rake is it? Any tips on using this type of hay rake (side rake)? I doesn't come with a manual so i have no idea how it works. Are parts still available for it? Anything I should look for when I look at it to know if it will be a good buy or a money pit?
Thank you.
Corey.
   / MF 36 Hay Rake, is it a good rake? #2
Is it PTO or ground driven.
   / MF 36 Hay Rake, is it a good rake? #4
I've used a mf 36 for the last 3 years. It was in rough shape when I bought it but it did the job well. Paid 100 bucks it crapped out this year. The internal gear drive sheared and I haven't had time to fix. They are fairly common so gettin a wrecked one for parts is easy enough. They are easy to use. Check the ground drive universals for excess play.
   / MF 36 Hay Rake, is it a good rake? #5
I have 2, pretty trouble free.
   / MF 36 Hay Rake, is it a good rake? #6
It has been great for me two years running. The tines can be bought from TSC. The two hole type not the single hole. But it does twist a tight windrow overall. If you want fluffy this does more rope type windrows. It is Very heAvy. It will hurt you or someone if not careful. Easily worth the 300 I paid. CG
2018 CATERPILLAR 12M3 MOTORGRADER (A52709)
2018 CATERPILLAR...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59230)
iDrive TDS-2010H...
2016 Jeep Compass 4X4 SUV (A56859)
2016 Jeep Compass...
2017 Ford F-650 Service Truck (A59230)
2017 Ford F-650...
2011 DOOSAN G25KW GENERATOR (A58214)
2011 DOOSAN G25KW...
2016 Lincoln Navigator SUV (A59231)
2016 Lincoln...
