MF 35 Regulator
/ MF 35 Regulator #1
Jons20
Hi,
I am a newbie here and looking for help.
I am currently bringing a Pos earth MF 35 back to life for sentimental reasons and would like some info on the voltage regulator, is it required with an alternator?
I have installed an alternator wired through a bulb on the dash and also changed from Pos to Neg Earth.
My question is can i get rid of the external Regulator now? Does the regulator in the alternator do the same job?
Hope you can help, thanks in advance.
Jon.
/ MF 35 Regulator #2
Hi,
Jon.
Yep! If your alternator has an internal reg, you won't need the old "black box".
/ MF 35 Regulator #3
Yep you can do away with that one now, we did that on my old Ford Hoe and a few of my lift trucks. When you referred to the MF35 as a POS is it one with a Perkins Gas burner. A friend of mine has 3 one is a Perkins Diesel and one Is the Contenintal gas and the other is a Perkins Gas and its the step child.
/ MF 35 Regulator
Hi,
Thanks for the reply.
Just to be sure, can you tell from the exterior if an alternator has an internal regulator as i thought all alternators had Regulators built into them.
Mine is a Three wire of a 1987 Ford escort.
Thanks again, Jon.
/ MF 35 Regulator
Hi,
Yeah its a Perkins 3 cylinder diesel.
Thanks,
Jon.
2009 ALLMAND MAXI-HEAT MH1000 HEATER TRAILER (A67714)
2009 ALLMAND...
2006 FORD F-150 XL TRITON EXT CAB TRUCK (A64276)
2006 FORD F-150 XL...
2015 Peterbilt 320 Roll-Off Truck (A66736)
2015 Peterbilt 320...
2009 FORD E350 CARGO VAN (A66091)
2009 FORD E350...
2014 MAC FLAMELESS HEATER (A68842)
2014 MAC FLAMELESS...
IRRIGATION PIPE FITTINGS (A64276)
IRRIGATION PIPE...
