MF 30E woes
/ MF 30E woes
Update to hydraulic problem: Yay !! It works !!! Took y'alls advice and drained all old fluid, removed and cleaned strainer (gooey), replaced and filled with Tractor Supply hydraulic fluid (12.5 gallons). Removed transfer pipe cap and cranked (w/out starting) engine until fluid pumped clear. Closed up everything and (fingers crossed) started engine. Whew !! "magic" everything worked. NOW....have to get to the Perkins problem. My first post says while working the loader, the engine developed a loud knock and started smoking from the crank case (it was pressurized). Engine ran strong, oil pressure okay, no black smoke, no white smoke. Something gave way internally but only symptoms were the knocking and pressurized crankcase. I'm tempted to run it until it "hand grenades" but then it may not be repairable. Any thoughts???
/ MF 30E woes #12
More info please?
When the knock occured, was it continuous, or knock for a bit (how long) and then stop?
I had a 135 do a main end bearing shell. It knocked loudly so I shut down quickly. Repairs were rings, bearing shells (crankshaft), and seals.Also the crankshaft needed honing to remove the bearing(some bits of bearing had stuck to the crankshaft). Because the engine was shut down quickly, there was no major damage. I did most of the repair myself, and the engine is just an oversized meccano set.
I reccommend you repair the engine now while it is fairly cheap. I would.
Good luck which ever way you decide.
/ MF 30E woes
The loud knocking occurred while I was working it hard to remove a tree stump. The loud knocking did not stop and also started blowing smoke from the crankcase. I agree with you, probably needs repair/rebuild. I have no problem tackling the engine rebuild, I just hate the thought of all the aggravation of having to remove the loader and rams and having to split the front of the tractor just to get at the little Perkins. :-( BTW, thanks for responding, I feel like I have some great help on this. :)
/ MF 30E woes #14
Yup, the tractor has been outside since I've owned it (about two months). It was outside in the rain where I bought it and who knows for how long.
And yes, rubber boots around all the shift levers look decrepit.......so I will drain the fluid and change/clean the filters to see if this remedies the problem. I will post the results when I finish. Thanks again for the tips.
You can get a CV shaft boot repair kit from the auto parts house and cut it down to fit over your gear shifter. They are very flexible and last.
2005 Freightliner M2 106 Ambulance (A59230)
2005 Freightliner...
2012 Ford F-250 Pickup Truck (A55973)
2012 Ford F-250...
1991 International 4900 Box Truck (A55315)
1991 International...
case 370 glass door never installed (A61307)
case 370 glass...
2014 Ford Escape SUV (A59231)
2014 Ford Escape...
2019 Deere 550K (A53317)
2019 Deere 550K...
