Mf 30 info
   / Mf 30 info #11
You need to go to the AGCO parts books website. If the book for the backhoe is there, then you should find a diagram and part numbers.
AGCO Parts Books
Either try admin as a login or get a free login and password from you Massey dealer.
Perhaps post a photo here of the parts you are talking about, as well.
Good luck with your new machine.
   / Mf 30 info
Thanks I think I found the parts I need. Now, my next questions. I'm pretty sure I have the 4 cyl Perkins engine on mine. I found some stuff stamped on the block. I'm hoping you guys can help me identify exactly which motor it is.
37112220/5
Bilchrome.
Thanks!
   / Mf 30 info #14
Well I bit the bullet and bought it. Got it home today and played around with it. Runs really pretty good just "smokes" or really sprays oil. Got a couple hydraulic minor hydronic leaks that I will have to fix if I get all the other kinks worked out. Backhoe digs pretty good too as far as I can tell. Where the barrel attaches to the frame of the hoe is cracked which allows for it to bounce around and have lots of slop. The bearings and/or bushings that go in the bottom of the barrel are completely gone. Does anyone have parts breakdown of a mf54 backhoe. So I can see if it looks like mine? Still going to have to figure out what bushings and/or bearings I'm going to need to replace... Thanks again for the help.
I called a Massey Ferguson dealer and they do have a breakdown on all your parts They just printed them out a week ago and ordered a bearing for mine. Mine was a needle bearing on top that was bad. A MF 54 n 54S r pretty much the same.
2016 PETERBILT 579 TANDEM AXLE SLEEPER (A52577)
2016 PETERBILT 579...
20' Multi Door One Way Ship Container (A52384)
20' Multi Door One...
2014 AMERITRAIL LAY FLAT HOSE TUGGER TRAILER (A52472)
2014 AMERITRAIL...
2017 Polaris 500 Ranger Diesel Utility Cart (A50324)
2017 Polaris 500...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52748)
80in HD Tooth...
2023 UNVERFERTH 432 (A53084)
2023 UNVERFERTH...
