Oil & Fuel MF 2675 Fuel Guage reading wrong
   / MF 2675 Fuel Guage reading wrong #1
Grantp
Mt. Elgin, Ontario
Massey Ferguson 2675 1983
I have a 2675, perkins 6.354 engine (just rebuilt) runs fine - but the fuel guage reads empty when half full, and just under half when the tank is topped up. All other electrics seem fine. Any suggestions on where to start troubleshooting
   / MF 2675 Fuel Guage reading wrong #2
At the sender.
Okey dokey - any clues as to what I should look for - when full should it be a specific voltage or amp reading? All wires appear to be OK, and connections are tight.
Thanks.
Grant
   / MF 2675 Fuel Guage reading wrong #4
G'day Grantp.
Remove the sender and bend the float arm down say two inches and try that and see if it is more accurate if not fit a new sender or do as most others do, Cut 18 inches of the end of mums broom and drill a hole in it ,fit a string loop and hang it up near the diesel bowser No electrics required and guaranteed to work EVERY TIME :dance1: .
Have a great day .
Regards.
Hutch.
G'day Grantp.
Have a great day .
Regards.
Hutch.
Thanks Hutch - I can't buy into the broom handle idea - too heavy, I use a 3/8" dowel painted black! So far, so good, but as the tractor improves with time (mine!) I'm trying to get most features working. I will try the float arm trick as soon as I finish the horse shelter. Thanks for responding! All the best and Good on ya!
BOX OF SCHUMACHER 6A BATTERY CHARGERS (A51248)
BOX OF SCHUMACHER...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A53473)
NEW HOLLAND 706 30...
UNUSED WOLVERINE BC-13-72W-72" HYD BRUSH CUTTER (A51248)
UNUSED WOLVERINE...
2014 CATERPILLAR 279D SKID STEER (A51246)
2014 CATERPILLAR...
UNUSED JCT HYD AUGER (A51248)
UNUSED JCT HYD...
2012 INTERNATIONAL DURASTAR 4400 4X2 SERVICE TRUCK (A51406)
2012 INTERNATIONAL...
