MF 263 Throttle Lever Issue
/ MF 263 Throttle Lever Issue #1
Farmingsabadhabit
Massey Ferguson 263
The throttle lever won't stay in position on my Massey Ferguson 263. When you pull the lever to raise the RPMs it won't hold position and slides back to idle. I know I could probably take it apart and figure it out but it's awful cold outside. Y'all got any quick fixes? Any place to adjust it so it stays in position?
/ MF 263 Throttle Lever Issue #2
Whichever controls you have, Classic or Ergonomic, nut #9 gets tightened until the throttle will hold. If it won't hold doing that, back off the nut, spray some brake cleaner on the friction disc #3, then tighten nut #9 again until throttle holds.
I think I know exactly where that is. I'll give it a try and let you know how it works out.
Well, I tightened that bolt but it didn't fix it. This is what I'm looking at:
/ MF 263 Throttle Lever Issue #6
I have a friction washer setup like that in my 88 Shibaura made Ford. Friction washer not designed to last 35+ years & part number discontinued of course, ended up using alternating nylon and steel washers to create multiple friction interface surfaces to tighten up with the nylock or castle nut -worked great
/ MF 263 Throttle Lever Issue #7
Definitely missing the friction washer. Look up a throttle friction washer for a Ford or MF like this:
2016 CATERPILLAR 416F2 BACKHOE (A63276)
2016 CATERPILLAR...
2019 Ford F250 4x4 Crew Cab Pickup Truck (A64194)
2019 Ford F250 4x4...
John Deere 1530 Tractor (A66285)
John Deere 1530...
4022CFL (A59228)
4022CFL (A59228)
2013 FORD F750 XLT SD SERVICE CRANE TRUCK (A62613)
2013 FORD F750 XLT...
BUYERS PREMIUM & PAYMENT TERMS (A59914)
BUYERS PREMIUM &...
