MF 2610 problem
/ MF 2610 problem #1
cfs
ontario Canada
mf 2610 tlb
this metal plate came off. :confused: i can't find a purpose for it. is it important? does anyone else have this problem.
/ MF 2610 problem #2
That would be a 'heat sheild'. It keeps the heat from the exhaust away from the starter.
Yes, it can be a problem. Just like the old Chevys, too much heat and the starter may not operate.
/ MF 2610 problem #3
How old is your machine?? The engine looks clean. It should be a warranty issue. If not, weld it up. Or if a bodyshop is nearby they should be able to do it for you. Just make sure to paint it so it does not rust.
/ MF 2610 problem
ya this was under waranty
2014 CATERPILLAR 259D SKID STEER (A65053)
2014 CATERPILLAR...
USA KB057-48" HYD BRUSH CUTTER (A65053)
USA KB057-48" HYD...
(39) Ratchet Straps (A65583)
(39) Ratchet...
New/Unused Wolverine 84in Quick Attach Rock Bucket (A65583)
New/Unused...
UNUSED 2023 JCB S3246E ELECTRIC SCISSOR LIFT (A65053)
UNUSED 2023 JCB...
BUSH HOG 4R48" BEDDER (A64278)
BUSH HOG 4R48"...
