Oil & Fuel MF 245 Smokes
/ MF 245 Smokes #1
mpoor
Dardanelle, Arkansas
massey fergusen 245
I am new to this forum and tractors in general. I am looking at buying a 1980 MF245 from a good friend. Its a diesel that runs great but smokes white smoke and smells like fuel, burns the eyes. He said he has replaced the injectors. What else can I check. BTW he is asking 5000 with a front end loader. Can any one of you help me out?
/ MF 245 Smokes #2
Make sure the headgasket is not leaking allowing coolant into the cylinder. If that's unburnt fuel, the check the airfilter for restriction. next would be a compression check and then the injectors and pump.
/ MF 245 Smokes
Thanks for the help. I'll check
/ MF 245 Smokes #4
You have a leaking head gasket. Water is getting into the cylinder and out the exhaust.Don't try to start the tractor as you risk hydraulicing the engine and doing major damage. Also ,when your friend started the tractor did the engine hesitate as it fired up?, if so that is another symptom of leaking head gasket. I was driving a JD 6920 that developed this problem on the job, I was told don't stop the engine until I got back to the yard. (keeping the engine running meant the water couldn't build up and hydraulic the engine.)
/ MF 245 Smokes
thank you for the help. I decided to buy another tractor, Ford 3910, but I will pass this info on to my friend.
3 Point Hay Forks (A62613)
3 Point Hay Forks...
Oxy-acetylene Torch and Regulator Rig (A63689)
Oxy-acetylene...
Straw Mulcher (A65579)
2012 PROCO 130BBL (A65643)
2012 PROCO 130BBL...
2020 International LT625 48" Sleeper (A62613)
2020 International...
2006 Cadillac GM Superior Coach 6-Door Limousine - Only 21,567 Miles (A63689)
2006 Cadillac GM...
