MF 240 the ones with the shut-off solinoid on the pump
   / MF 240 the ones with the shut-off solinoid on the pump #1
DLTTrekkers
Paarl South Africa
I have a MF 240 that runs and work great , but when I throttle down to idle and then jusks the throttle to full revs it starts to spatter like a petrol engine with a carburator that gets flooded .
If I take the revs up slow it runnes fine .
Help to diagnose ?
   / MF 240 the ones with the shut-off solinoid on the pump #2
How does it behaves when it's under load?
In 40 years working on tractors this is my first time experiancing something like that !
   / MF 240 the ones with the shut-off solinoid on the pump #5
Sounds like injectors that need a good cleaning.. spray pattern is not atomizing the fuel & its "flooding" the cylinder w/ fuel..
Does it BLACK smoke when it does it.??
IF no smoke.. check the filters..
No black smoke.
I went thru the fuelsisteme...check all ....no problems.
   / MF 240 the ones with the shut-off solinoid on the pump #7
TRY all your tests WITHOUT the air cleaner..& its best if u can pull the hose right off the intake manifold..
Have u tried moving the pump timing any.?? Find the timing marks on the pump flange & engine block,
& make a note as to where its at NOW.. THEN loosen the 3 pump bolts & twist the pump 1-2* one way or the other..
& TIGHTEN IT BACK DOWN BEFORE U START THE ENGINE!!! VERY IMPORTANT..
Good luck.
   / MF 240 the ones with the shut-off solinoid on the pump #8
Good luck.
Do pumps "advance" the fuel pulse to the injectors for higher rpm like the spark on gas engines?
   / MF 240 the ones with the shut-off solinoid on the pump #9
Most ALL "rotary pumps" do.. they have an advance mechanism on the lower side of the pump housing..
   / MF 240 the ones with the shut-off solinoid on the pump #10
DL.. U have a CAV pump right.?? IF its not painted over.. theres an arrow on the name tag..
To advance the timing.. u turn the pump OPPOSITE the direction of the arrow..{1-2*}
I hope this helps..
2020 Kubota SVL75-2 (A50123)
2020 Kubota...
2017 KOMATSU PC228USLC-10 EXCAVATOR (A51246)
2017 KOMATSU...
2005 International TranStar 8600 Hydro Vac Truck (A53117)
2005 International...
10' WROUGHT IRON SITE FENCE (A51248)
10' WROUGHT IRON...
REIST R25PSS LOT NUMBER 58 (A53084)
REIST R25PSS LOT...
2009 Chevrolet Malibu Sedan (A51694)
2009 Chevrolet...
