MF 231S FEL hydraulic pump problem
   / MF 231S FEL hydraulic pump problem #1
fireman4074
MF 231S
I have MF 231S with FEL. The hydraulic pump that operate the FEL just stop working, Pump is located in front of tractor as noted in picture. Pump has a shaft that goes into something I guess that turns with the crankcase. With the motor off, I can turn the shaft freely with out any problem which mean something have happen inside that area. Have anyone have this problem if so what is the process of fixing this issue. Thanks in advance
   / MF 231S FEL hydraulic pump problem #2
The other end is bolted to the crankshaft , should have a small u joint on it
The other end is bolted to the crank shaft , should have a small u joint on it
Okay Thanks but what all do I have to remove to get to it like radiator.
   / MF 231S FEL hydraulic pump problem #4
Can you look down from the top or side to see the front of the engine
   / MF 231S FEL hydraulic pump problem #5
From the side all i can see is the fan belts and bottom where crankcase and shaft is under radiator and more stuff.
   / MF 231S FEL hydraulic pump problem #8
Did you look at the picture its there , Can you pull the shaft on the engine is it loose , It should be tight no slop
   / MF 231S FEL hydraulic pump problem #9
I dont know if you can get in there to work with the loader arms in the way. You should not have to take it apart like that Just a picture so you know what to look for
Yes it do have slack. In one of my pic, you can see that shaft had enough shaft for me to push it back from the pump without any problem.
2008 FORD F550 XL SUPER DUTY DUMP TRUCK (A51406)
2008 FORD F550 XL...
2025 New/Unused Wolverine 72in Skid Steer Hydraulic Rotary Tiller (A51573)
2025 New/Unused...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
2013 INTERNATIONAL MA025 ROUSTABOUT (A52472)
2013 INTERNATIONAL...
2005 GMC Sierra Pickup Truck, VIN # 2GTEK13T851399344 (A51572)
2005 GMC Sierra...
2020 TAKEUCHI TL 12V-2 (A52472)
2020 TAKEUCHI TL...
