mf 231 leaking oil
   / mf 231 leaking oil #1
mf231
mf 231
mf 231 leaking oil badly out of weep hole in belly of tractor....replaced rear main seal.....still leaking???anyone have anymore suggestions. My guy working on it is stumped...Thanks in advance
   / mf 231 leaking oil #2
it can only be coming from the front of the transmission or rear of the engine. Engine oil and hyd oil smell differently if that helps.
its def oil......any other poss place it could come from..my guy said the orginal and the new seal looked fine when he got it apart...its back apart now
   / mf 231 leaking oil #4
Sorry to hear this, seals can sometimes wear a slight groove into the crankshaft and not seal fully. I'm sure your mechanic checked this. Try a high mileage engine oil. It has a seal sweller additive in it. It may or may not help. How many hours are on the engine? Are you sure the pan gasket is not "sweating" oil?
2001 Club Car Carryall Utility Cart (A51691)
2001 Club Car...
Adams FL24 Fertilizer Conveyor - 24IN Belt, Predator Engine, 2IN Hitch, Refurbished by Manufacturer (A52128)
Adams FL24...
(8) 2 PLUG VALVES (A52472)
(8) 2 PLUG VALVES...
Case 580D (A47384)
Case 580D (A47384)
2015 CATERPILLAR 303.5E2 CR EXCAVATOR (A51242)
2015 CATERPILLAR...
2020 Bobcat T76 R-Series (A47384)
2020 Bobcat T76...
