MF 202 1963 model/year Power steering problems
   / MF 202 1963 model/year Power steering problems #1
thomasmoore
union sc
case/MF/Ford
I have a 1963 model MF 202 in my shop with steering problems. I first replaced the pump due to low pressure issues. Power steering still not working. I removed the control valve mounted on the steering column. There does not seem to be any internal O-rings or seals, only the ones to keep oil from leaking externally. There is no obvious damage or wear as seen by the naked eye to the valve components, only 51 years worth of crud to be cleaned. The only other components of the system are the two steering cylinders which I intend to repack.
My question is...Has anyone dealt with this issue and can you please offer any help?
   / MF 202 1963 model/year Power steering problems #2
I had an old MF203 that I rebuilt the PS on more than once. That spool at the column is a strange device that never made sense. Steering box is a recirculating ball arrangement.
I would suspect the spool (valve) is bypassing somehow. I know that doesn't help much.
I'm trying to recall what I ran across... its been a while and I no longer have the manuals.
   / MF 202 1963 model/year Power steering problems #3
Does your power steering work at all?
Is it better one way and not the other?
Put your hand on both steering cylinders to get a feel for what temperature they are.
Start tractor and turn the wheel back and forth and then have someone hold it at full lock to the left and then retouching each steer cylinder to feel for a heat build up in the outer portion of the cylinder. Repeat for right side. Do it several times each way. If one cylinder starts to warm up while the other stays close to it's starting temp, that cylinder is bypassing.
I fear your problem is under the dash, but you need to rule out the bypass first.
Did you bleed it off after you changed the pump out?
2025 Mower King SSECAG-Y (A50123)
2025 Mower King...
2000 Wabash National 53ft T/A Dry Van Trailer (A51692)
2000 Wabash...
20 ft Angle Boom (A53117)
20 ft Angle Boom...
2015 PCI MFG. SOLUTIONS 130 BBL STEEL VACUUM TRAILER (A53843)
2015 PCI MFG...
2024 Dig Master DM100 Mini Excavator, NEW! (A52384)
2024 Dig Master...
2018 Mac 48FT. T/A Walking Floor Trailer (A51692)
2018 Mac 48FT. T/A...
