thomasmoore
I have a 1963 model MF 202 in my shop with steering problems. I first replaced the pump due to low pressure issues. Power steering still not working. I removed the control valve mounted on the steering column. There does not seem to be any internal O-rings or seals, only the ones to keep oil from leaking externally. There is no obvious damage or wear as seen by the naked eye to the valve components, only 51 years worth of crud to be cleaned. The only other components of the system are the two steering cylinders which I intend to repack.
My question is...Has anyone dealt with this issue and can you please offer any help?
