onceacop
Down to these 2 MF tractors. I priced out the only 2 dealers within 100 miles as I am near the Canada border in northern MN. Had green and red to chose from. The JD 4052R cab with wheel weights, 3 rd control on loader for snow blade, radio, self level bucket and susp. package on loader with R1 tires came in at $49500, the 4066R was $54695.
The MF 1758 with radio, R1loaded tires upgraded to 16.9's, block htr, 3rd function on 130 loader and joy stick, radio, and some other extras is around $42500. As you know the 1758 is HST trans. I found a 1759 with the 12x12 shuttle for about the same $.
I am quite impressed with the quality of both the JD and Massey but like the metal components of the Massey. The cab works for me also.
My questions are this:
1.) I travel sometimes up to 10 miles away (one direction) to cut firewood on federal lands using a permit. I pull a trailer and take sometimes over a 1-2 chords home. Does an advantage of roading a tractor long distances go to a regular transmission over a HST or is there little difference in fuel economy and durability between the two?
2.) I am on a airplane runway mowing with this unit and on hunting trails and near buildings. Should I not load the tires and just go with a ballast box when needed? I want to R1 tires as I am not impressed with R4's for field work and muddy conditions in the woods. Dealer says to load tires and be done with it.
3,) It was -25F this am. If I am in a very cold climate would the nod of approval go to either HST or 12x12 transmission or does it matter little?
Thanks in advance
Thanks in advance
