MF 165
/ MF 165 #1
CircleJFarm
A friend of mine has a 165 and the 3point lift arms will not operate up/down. Several years ago I purchased a TO20 with the same problem. I dropped the pump and replaced the relief valve. Could this be the same problem? Any help would be great!!
/ MF 165 #2
Could be, probably not though. Best to get a manual and do some tests. Same idea as your older tractor but a little more in depth. Some troubleshooting would give a better idea. Do the arms shutter at all? There is a round cover on the right side, if you drain a little fluid & open it you can manually run the pump so kinda test it. That will give you some direction if it's pump, lift cylinder or something else.
International 490 Disc (A65640)
International 490...
25 Traffic Cones (A65583)
25 Traffic Cones...
LOOK! (A63109)
LOOK! (A63109)
Dueling Tree (A65640)
JOHN DEERE 5100 TRACTOR (A63291)
JOHN DEERE 5100...
Bulk Lot - (10) 8in x 20ft Fat Lip Pump Hoses (A63689)
Bulk Lot - (10)...
