MF 165 rebuild
/ MF 165 rebuild #1
JHR MF CUMBRIA UK
I am going to get my 165 engine rebuilt and not sure if for a complete rebuild including the following will need the engine to be removed. Also what do you reckon of the agriline kits or should i go for genuine Perkins?
What price should i expect to pay to get it done?
4 x 7360 Piston - 3.5 Bore - Five Rings - Pimple Bowl,
4 x 7190 Piston Ring Set - 5 Ring,
4 x 7278 Liner finished,
1 x 7079 Head Gasket Set 203 engine,
1 x 7075 Lower gasket set,
1 x 7057 Lower gasket set,
1 x 7255 Crankshaft Seal - Front,
4 x 7416 Valve Inlet,
4 x 7415 Valve Exhaust,
4 x 7417 Valve Spring Inner,
4 x 7418 Valve Spring Outer,
16 x 7377 Valve Collet,
8 x 7419 Valve Guide,
4 x 7033 Small End Bush
Thanks in advance for any help.
2014 Kawasaki 70Z7 Articulated Wheel Loader (A64553)
2014 Kawasaki 70Z7...
New 1.5x27 Ratchet Strap (A65579)
New 1.5x27 Ratchet...
MechMaxx Grinder Betsco Flail mower
MechMaxx Grinder...
2009 V.E. ENTERPRISES 130BBL VACUUM TRAILER (A65643)
2009 V.E...
2022 DODGE RAM 2500 (A65643)
2022 DODGE RAM...
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
