MF 165 perkins 4-203 engine cooling question
   / MF 165 perkins 4-203 engine cooling question #1
johnb1
perth australia
mf 165 perkins 4-203
I have replaced water pump and hoses on my MF 165. There are 2 bottom hoses and a metal pipe that go between the pump and the bottom of the radiator. The metal pipe is badly corroded and needs to be replaced. I can't find a replacement pipe and am wondering if anyone else has had this problem. Maybe there is an alternate hose that would do the job. Any advice would be appreciated.
John
   / MF 165 perkins 4-203 engine cooling question #2
Have you asked a MF dealer? MF has an excellent parts policy on older tractors, quite cheap too in my part of the world.
   / MF 165 perkins 4-203 engine cooling question #3
John, if you have no luck with the dealer, try a Bepco or a Sparex agent. You'll be surprised what they have - albeit usually in non-genuine parts, but I've had no problems with everything I've bought from our Bepco agent here in Brisbane. :thumbsup:
Alternatively, maybe an exhaust shop can bend up a replacement from stainless steel pipe. Bear in mind, I have no idea what the pipe looks like!
Best of luck. :)
Thanks for the replies. I've checked out the local MF dealers and had no problem getting a new water pump and hose kit but no help with the pipe. They say that they often get requests for this pipe but don't know what people do to solve the problem. They have also suggested going to an exhaust shop. Will check with Bepco and Sparex.
parex
   / MF 165 perkins 4-203 engine cooling question #5
G'day John a piece of stainless exh tube will fix it
Jon
Unverferth Brent CPC PT 16' Disc Ripper (A50120)
Unverferth Brent...
2007 John Deere CT332 Skidloader (RIDE AND DRIVE) (A50774)
2007 John Deere...
2007 Volvo VNL Truck Tractor (A52748)
2007 Volvo VNL...
2016 Kawasaki 70 TM 7 Articulating Wheel loader (A52748)
2016 Kawasaki 70...
2013 Dodge Avenger Sedan (A50324)
2013 Dodge Avenger...
2015 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A52577)
2015 FREIGHTLINER...
