MF 165 identifaction
   / MF 165 identifaction #1
Sean165
Greer, sc
MF 165
The serial number on my Perkins engine is 29D6387 -does this mean it was produced prior to May 31, 1966? Can any further identification as to the year be determined? Thanks
   / MF 165 identifaction #2
Should be a tractor SN tag on lower dash panel below battery cover, that is # needed to find build year.
Thanks - I will check. Also, I did talk to you last week concerning the injector pump. I am in the process of taking it off to send you - I will call to confirm the address,etc. in regards to taking it off - can I just remove the crankcase fill port small plate, than remove the 3 bolts from the gear - leaving the dowel pin and gear in place?
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
2016 FORD F-350 XL SUPER DUTY CREW CAB FLATBED (A51243)
2016 FORD F-350 XL...
HOPKINS 40 TRI-AXLE DATA VAN TRAILER (A50854)
HOPKINS 40...
2022 FREIGHTLINER M2 24FT BOX TRUCK (A51222)
2022 FREIGHTLINER...
2019 PRINOTH PANTHER T14R CRAWLER (A51242)
2019 PRINOTH...
PLEASE VIEW ALL PICTURES!! (A50774)
PLEASE VIEW ALL...
