MF 165 help, manual and info
   / MF 165 help, manual and info #1
foxy87lady
MF165
Have a MF 165 with different issues when bought used. Looking for a manual to help with fixing and to figure out what guage the different wires should be in the wiring harness. Does anyone know how to tell if the ignition switch is good or bad? Thank you in advance! J
   / MF 165 help, manual and info #2
You can try to fid reproduction copies of manuals on ebay, Yesterday's Tractors web site, and finally, www..jensales.com( most expensive).
You can check an ignition switch with an ohm meter( switch on ~0 ohms, switch off, infinite ohms) or you can jump across it with a jumper wire and if what ever your problem was goes away, the switch is bad.
What's the problem with your tractor?
PALLET OF MISC LINCOLN ARC WELDER, AIR COMPRESSOR (A51244)
PALLET OF MISC...
2017 Ford F-150 Ext. Cab Pickup Truck (A50323)
2017 Ford F-150...
2014 Ford E-350 Cargo Van (A50323)
2014 Ford E-350...
2019 CATERPILLAR 308 CR EXCAVATOR (A50458)
2019 CATERPILLAR...
Caterpillar D7G Bulldozer (A50514)
Caterpillar D7G...
2021 ASV POSI-TRACK RT-120 FORESTRY SKID STEER (A51242)
2021 ASV...
