MF 165 help, manual and info
   / MF 165 help, manual and info #1
foxy87lady
MF165
Have a MF 165 with different issues when bought used. Looking for a manual to help with fixing and to figure out what guage the different wires should be in the wiring harness. Does anyone know how to tell if the ignition switch is good or bad? Thank you in advance! J
   / MF 165 help, manual and info #2
You can try to fid reproduction copies of manuals on ebay, Yesterday's Tractors web site, and finally, www..jensales.com( most expensive).
You can check an ignition switch with an ohm meter( switch on ~0 ohms, switch off, infinite ohms) or you can jump across it with a jumper wire and if what ever your problem was goes away, the switch is bad.
What's the problem with your tractor?
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A51222)
2019 INTERNATIONAL...
2024 AGT KFE-20 2,000lb Electric Forklift (A50322)
2024 AGT KFE-20...
2024 New Holland T8.410 MFWD Tractor (A52128)
2024 New Holland...
1994 FORD F450-SUPER DUTY FLATBED (A51219)
1994 FORD...
2007 FREIGHTLINER BUSINESS CLASS M2 DUMP TRUCK (A51406)
2007 FREIGHTLINER...
2021 CATERPILLAR 259D3 SKID STEER (A51242)
2021 CATERPILLAR...
