MF 165 help, manual and info
   / MF 165 help, manual and info #1
foxy87lady
MF165
Have a MF 165 with different issues when bought used. Looking for a manual to help with fixing and to figure out what guage the different wires should be in the wiring harness. Does anyone know how to tell if the ignition switch is good or bad? Thank you in advance! J
   / MF 165 help, manual and info #2
You can try to fid reproduction copies of manuals on ebay, Yesterday's Tractors web site, and finally, www..jensales.com( most expensive).
You can check an ignition switch with an ohm meter( switch on ~0 ohms, switch off, infinite ohms) or you can jump across it with a jumper wire and if what ever your problem was goes away, the switch is bad.
What's the problem with your tractor?
2017 Buick Regal Sedan (A50324)
2017 Buick Regal...
New 4-235/80R16 Montreal Trailer Tires (A50774)
New 4-235/80R16...
UNUSED CFG Industrial QK16R Mini Excavator (A47384)
UNUSED CFG...
2018 BOBCAT T450 SKID STEER (A51242)
2018 BOBCAT T450...
2020 Takeuchi TL10V2 (A47384)
2020 Takeuchi...
2005 Case IH 2062 Flex Draper Header (A50657)
2005 Case IH 2062...
