MF 165 fuel lines
   / MF 165 fuel lines #1
Sean165
Greer, sc
MF 165
In my hast to have the injector pump rebuilt - I did not mark where the two fuel lines from the pump go ( I know back to the fuel filter) , but which outlet. There are two places on the filter marked with arrows ( one pointing in and the other pointing out). From the pump - the end where the injector lines are coming out - there is a fuel line - does that return fuel or bring fuel
Thanks
   / MF 165 fuel lines #2
Thanks
The arrows indicate the floow direction. In other words. From the fuel tank to injectors or carb, the arrows should go with the flow. :thumbsup:
   / MF 165 fuel lines #3
Fuel line connection at drive end of pump is return back to filter base, pump inlet next to injector line banjos line is connected to filter base outlet arrow.
2016 Chevrolet Tahoe SUV (A52377)
2016 Chevrolet...
2023 GMC 3500 Bed (A51573)
2023 GMC 3500 Bed...
2024 JOHN DEERE 461M LOT NUMBER 60 (A53084)
2024 JOHN DEERE...
2016 TANKKO 130BBL VAC TRAILER (A52472)
2016 TANKKO 130BBL...
44in Tooth Excavator Bucket (A51691)
44in Tooth...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
