MF 165 fuel lines
/ MF 165 fuel lines #1
Sean165
Greer, sc
MF 165
In my hast to have the injector pump rebuilt - I did not mark where the two fuel lines from the pump go ( I know back to the fuel filter) , but which outlet. There are two places on the filter marked with arrows ( one pointing in and the other pointing out). From the pump - the end where the injector lines are coming out - there is a fuel line - does that return fuel or bring fuel
Thanks
/ MF 165 fuel lines #2
Thanks
The arrows indicate the floow direction. In other words. From the fuel tank to injectors or carb, the arrows should go with the flow. :thumbsup:
/ MF 165 fuel lines #3
Fuel line connection at drive end of pump is return back to filter base, pump inlet next to injector line banjos line is connected to filter base outlet arrow.
